MSI Mass Deployment
Rich_
Rich_ Posts: 3
We are currently in the process of a mass deployment and have the MSI configured so all machines will join the "new installs" group. The MSI is configured so that all machines will join with their service tag. We are not setting up any machine with unattended access. But it looks like the initial connection will require input from the end user. They will need to provide their password, and then after the initial connection we can prompt the user to allow, which is the desired behavior. Is there any way to get around the initial connection requiring the end user's password? This will be a long and tedious deployment if we have to do that for every machine.
  • Ying_Q
    Ying_Q Posts: 2,601 Moderator
    Hi @Rich_ ,
    If you are aiming to set up unattended access with MSI Deployment, it should ask the enduser to confirm the account assignment without telling the password. However, as MSI Deployment can be complicated in different scenarios, we suggest you to contact TeamViewer Support Team for further assistnance and discussion on your settings and goals on TeamViewer MSI deployment.
    Thank you for your understanding and hope your case can be fixed soon.
    Community Moderator/中文社区管理员
  • Rich_
    Rich_ Posts: 3
    Hi Ying. Thank you for the response. As stated in my original post we are not aiming to setup with unattended access. Just the opposite. We want to require the end user to accept the connection. The deployment works, but requires the end user to provide their password for the initial connection. Thereafter, we can prompt the user to allow access, which is how we want this setup.  This would require us to reach out to each end user after deployement, get their password, and establish a connection. That is a time consuming process that we are trying to avoid. Thanks for input.
    @Ying_Q wrote:
    Hi @Rich_ ,
