Teamviewer 15.1.3937 Crashes Constantly
Hi All!
Having a lot issues with teamviewer since the update, I work within an IT envirnoment and have many vm's and pcs on my remote management.
When I try to help clients with issues teamviewer keeps conts
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @SCramp,
    Thank you for your post and we are sorry to hear the negative experience from you.
    In order to assist you with a better possible solution, can you kindly contact TeamViewer Support Team and discussion the issue you have encounter with TeamViewer please.
    We are sorry for the inconvenience caused and hope your case will be resolved soon.
    Community Moderator/中文社区管理员
