Can't reinstall Teamviewer - "Rollback framework could not be initialized"
PLEASE READ THE ENTIRE POST! I'VE ALREADY TRIED ALL SOLUTIONS CURRENTLY AVAILABLE ON THESE FORUMS.
I can't seem to reinstall Teamviewer after previously uninstalling it. The error says: "Rollback framework could not be initialized. Installation aborted!" I tried updating the .NET framework, and running the installer as administrator, but neither of those worked and there aren't any solutions online. I also tried deleting the folder: "C:\Users\**yourusernamehere**\AppData\Local\Temp\TeamViewer" to no avail. It deleted, but TeamViewer still won't install. If you have any ideas, let me know? Thanks.
  • Giovanni
    Giovanni Posts: 49 [Former Staff]
    Dear @musicissilver
    This issue you described could be caused by corrupted registry keys left behind by a faulty installation, or a Windows update.
    Please try the following:
    -Remove any versions of TeamViewer via the add/remove programs option from Control Panel.
    -Go to Regedit: remove the full TeamViewer folders located in
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\]
    [HKEY_CURRENT_USER\SOFTWARE\]
    and if there the folder "TVInstallTemp" (also located in [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\] )
    -Also, please delete the entire TeamViewer folder located in %temp%
    -Restart the machine.
    -Disable all the Antivirus/security software
    -Reinstall a fresh copy of TeamViewer from our website and during the installation select "advance" and change the installation path from C:\Program Files (x86)\TeamViewer to C:\TeamViewer
    I hope this solves the issue.
    Giovanni
    Giovanni
  • Sextant
    Sextant Posts: 1
    I have the same problem, tried your suggested solution, but still didn't work. Thanks.
  • TimHL
    TimHL Posts: 1
    Running the installer when logged in with the Administrator accout on my PC worked.  Using right-click Run as Administrator when logged in as a non-Admin user always failed with the rollback framework error.
  • This was a solution for me on a Windows 7 laptop. I enabled the Windows 7 admin account using Ultimate Windows Tweaker. Many thanks for providing me with a solution!
