Keep a disconnected computer in a group
preaud
Hi All,
Is it possible to keep the Computer in a group anytime ? When the computer is not connected, we can't see it in the group... it's going to the buttom list in the "Disconnected" group.
Thank you in advance for your answer.
Best regards
Philippe
Hi @preaud
Offline computer are shown in a separate group. If you like, you could change this in your options.
Please go to Computer & Contacts in your TeamViewer options and unhook the setting
"Offline computers & contacts in separate group"
CheersReyhan
Reyhan0
