Connect to Chromebook remotely
How can I connect to a Chromebook remotely, can't find out how to do this
I can download an app, but it does not work
Very bad informaiton, bad design can this be done?
  • Reyhan
    Hi @t8769
    Please have a look at this helpful article here
    Cheers.
    Reyhan
    Hello @t8769,
    We are happy to announce that you can now share the screen of your devices running ChromeOS. ?
    If you want to connect via unattended access, please use the TeamViewer Host.
    If you want to connect spontaneously, please use the TeamViewer QuickSupport.
    You will find the download links here:
    Alternatively, you can also download these versions directly on our website here: TeamViewer for Chrome OS
    Please also find additional information here: Supported platforms - Chrome OS
