Teamviewer Vpn blocked with Windows Firewall
I am using Teamviewer 12 and would like to use the VPN option. I installed it all and it works perfectly only if I turn off the Windows firewall on my VPN target pc
My target pc have windows 10 installed
I need to setup any rule?
I don't want disable windows firewall
Please Show firewall log entry showing how fierwall is blocking your TV connection.Regards,
mLipok , AutoIt MVP0 -
#Version: 1.5
#Software: Microsoft Windows Firewall
#Time Format: Local
#Fields: date time action protocol src-ip dst-ip src-port dst-port size tcpflags tcpsyn tcpack tcpwin icmptype icmpcode info path
2017-04-17 07:44:21 ALLOW UDP 192.168.0.1 192.168.0.219 56760 137 0 - - - - - - - RECEIVE
2017-04-17 07:44:28 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 49917 1900 0 - - - - - - - SEND
2017-04-17 07:44:28 ALLOW UDP ::1 ff02::c 49918 1900 0 - - - - - - - SEND
2017-04-17 07:44:28 ALLOW UDP ::1 ::1 1900 49918 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW 2 7.165.156.217 224.0.0.22 - - 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::1:3 56230 5355 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 224.0.0.252 56230 5355 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP fe80::ac50:501b:a879:6360 ff02::1:3 51269 5355 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 7.165.156.217 224.0.0.252 51269 5355 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW ICMP :: ff02::1:ff79:6360 - - 0 - - - - 135 0 - SEND
2017-04-17 07:45:03 ALLOW ICMP fe80::ac50:501b:a879:6360 ff02::2 - - 0 - - - - 133 0 - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 239.255.255.250 51726 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ff02::c 51727 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ff02::c 51727 3702 0 - - - - - - - RECEIVE
2017-04-17 07:45:03 ALLOW UDP 127.0.0.1 239.255.255.250 51726 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 127.0.0.1 239.255.255.250 51726 3702 0 - - - - - - - RECEIVE
2017-04-17 07:45:03 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 51727 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 7.165.156.217 7.255.255.255 137 137 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP fe80::ac50:501b:a879:6360 ff02::1:2 546 547 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ::1 51272 51272 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ::1 49918 49918 0 - - - - - - - SEND
2017-04-17 07:45:03 DROP UDP 7.144.100.93 239.255.255.250 61060 3702 1107 - - - - - - - RECEIVE
2017-04-17 07:45:03 ALLOW TCP ::1 ::1 50305 5357 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP ::1 ::1 50305 5357 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:03 DROP UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 51277 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 DROP UDP ::1 ff02::c 51277 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 192.168.0.1 52469 53 0 - - - - - - - SEND
2017-04-17 07:45:03 DROP UDP 192.168.0.219 239.255.255.250 51276 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 DROP UDP 127.0.0.1 239.255.255.250 51276 3702 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 127.0.0.1 239.255.255.250 1900 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 239.255.255.250 1900 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ff02::c 1900 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 1900 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 192.168.0.1 59065 53 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW TCP 127.0.0.1 127.0.0.1 50306 5357 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 127.0.0.1 127.0.0.1 50306 5357 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:03 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 129 - - - - - - - RECEIVE
2017-04-17 07:45:03 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 155 - - - - - - - RECEIVE
2017-04-17 07:45:03 DROP UDP 7.144.100.93 239.255.255.250 54467 3702 652 - - - - - - - RECEIVE
2017-04-17 07:45:03 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 165 - - - - - - - RECEIVE
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 104.106.125.79 50307 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 127.0.0.1 127.0.0.1 50309 5357 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 127.0.0.1 127.0.0.1 50309 5357 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 88.221.145.40 50308 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 51270 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP ::1 ff02::c 51272 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 239.255.255.250 51273 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW UDP 127.0.0.1 239.255.255.250 51275 1900 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW TCP ::1 ::1 50310 5357 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP ::1 ::1 50310 5357 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:03 DROP UDP 7.144.100.93 224.0.0.252 51640 5355 61 - - - - - - - RECEIVE
2017-04-17 07:45:03 ALLOW UDP 192.168.0.219 192.168.0.1 55448 53 0 - - - - - - - SEND
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 13.107.4.50 50311 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 13.107.4.50 50314 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 13.107.4.50 50313 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 ALLOW TCP 192.168.0.219 13.107.4.50 50312 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:03 DROP UDP 7.144.100.93 224.0.0.252 56607 5355 61 - - - - - - - RECEIVE
2017-04-17 07:45:04 ALLOW ICMP fe80::ac50:501b:a879:6360 ff02::1 - - 0 - - - - 136 0 - SEND
2017-04-17 07:45:04 ALLOW UDP fe80::ac4b:2f46:fdba:b9c2 ff02::1:3 55772 5355 0 - - - - - - - SEND
2017-04-17 07:45:04 ALLOW UDP 192.168.0.219 224.0.0.252 55772 5355 0 - - - - - - - SEND
2017-04-17 07:45:04 ALLOW UDP fe80::ac50:501b:a879:6360 ff02::1:3 59614 5355 0 - - - - - - - SEND
2017-04-17 07:45:04 ALLOW UDP 7.165.156.217 224.0.0.252 59614 5355 0 - - - - - - - SEND
2017-04-17 07:45:04 DROP UDP 7.144.100.93 239.255.255.250 54467 3702 652 - - - - - - - RECEIVE
2017-04-17 07:45:04 DROP UDP 7.144.100.93 224.0.0.252 56607 5355 61 - - - - - - - RECEIVE
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50315 2869 0 - 0 0 0 - - - SEND
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50315 2869 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50316 2869 0 - 0 0 0 - - - SEND
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50316 2869 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50317 2869 0 - 0 0 0 - - - SEND
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50317 2869 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50318 2869 0 - 0 0 0 - - - SEND
2017-04-17 07:45:04 ALLOW TCP ::1 ::1 50318 2869 0 - 0 0 0 - - - RECEIVE
2017-04-17 07:45:04 DROP UDP 7.144.100.93 224.0.0.252 53956 5355 61 - - - - - - - RECEIVE
2017-04-17 07:45:04 ALLOW UDP ::1 ::1 1900 51272 0 - - - - - - - SEND
2017-04-17 07:45:04 DROP UDP 7.144.100.93 224.0.0.252 56263 5355 50 - - - - - - - RECEIVE
2017-04-17 07:45:05 DROP UDP 7.144.100.93 224.0.0.252 53956 5355 61 - - - - - - - RECEIVE
2017-04-17 07:45:05 DROP UDP 7.144.100.93 239.255.255.250 56264 3702 652 - - - - - - - RECEIVE
2017-04-17 07:45:05 DROP UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 59616 3702 0 - - - - - - - SEND
2017-04-17 07:45:05 DROP UDP ::1 ff02::c 59616 3702 0 - - - - - - - SEND
2017-04-17 07:45:05 DROP UDP 192.168.0.219 239.255.255.250 59615 3702 0 - - - - - - - SEND
2017-04-17 07:45:05 DROP UDP 127.0.0.1 239.255.255.250 59615 3702 0 - - - - - - - SEND
2017-04-17 07:45:05 DROP UDP 7.144.100.93 224.0.0.252 56263 5355 50 - - - - - - - RECEIVE
2017-04-17 07:45:05 ALLOW UDP 127.0.0.1 127.0.0.1 1900 51275 0 - - - - - - - SEND
2017-04-17 07:45:05 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 165 - - - - - - - RECEIVE
2017-04-17 07:45:06 DROP UDP fe80::ac4b:2f46:fdba:b9c2 ff02::c 59616 3702 0 - - - - - - - SEND
2017-04-17 07:45:06 DROP UDP ::1 ff02::c 59616 3702 0 - - - - - - - SEND
2017-04-17 07:45:06 ALLOW UDP 192.168.0.219 192.168.0.255 137 137 0 - - - - - - - SEND
2017-04-17 07:45:06 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 129 - - - - - - - RECEIVE
2017-04-17 07:45:06 DROP UDP 192.168.0.219 239.255.255.250 59615 3702 0 - - - - - - - SEND
2017-04-17 07:45:06 DROP UDP 127.0.0.1 239.255.255.250 59615 3702 0 - - - - - - - SEND
2017-04-17 07:45:06 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 155 - - - - - - - RECEIVE
2017-04-17 07:45:06 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 165 - - - - - - - RECEIVE
2017-04-17 07:45:07 ALLOW TCP 192.168.0.219 65.52.108.90 50323 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:07 DROP ICMP 7.144.100.93 7.165.156.217 - - 60 - - - - 8 0 - RECEIVE
2017-04-17 07:45:08 DROP UDP 7.144.100.93 224.0.0.252 52742 5355 50 - - - - - - - RECEIVE
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 13.107.4.50 50324 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 13.107.4.50 50325 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 13.107.4.50 50326 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 13.107.4.50 50327 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 212.131.108.154 50328 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 ALLOW TCP 192.168.0.219 40.77.229.141 50329 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:08 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 165 - - - - - - - RECEIVE
2017-04-17 07:45:09 DROP UDP 7.144.100.93 7.255.255.255 138 138 214 - - - - - - - RECEIVE
2017-04-17 07:45:09 ALLOW TCP 192.168.0.219 104.106.125.79 50330 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:09 ALLOW UDP 192.168.0.219 192.168.0.1 61056 53 0 - - - - - - - SEND
2017-04-17 07:45:09 ALLOW TCP 192.168.0.219 88.221.145.43 50331 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:09 ALLOW TCP 192.168.0.219 88.221.145.43 50333 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:09 ALLOW TCP 192.168.0.219 88.221.145.43 50332 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:09 ALLOW TCP 192.168.0.219 88.221.145.43 50334 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:10 DROP UDP 7.144.100.93 7.255.255.255 138 138 214 - - - - - - - RECEIVE
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 104.106.125.79 50335 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 40.77.226.250 50336 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 104.106.125.79 50338 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 88.221.145.40 50337 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW UDP 192.168.0.219 192.168.0.1 59571 53 0 - - - - - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 88.221.145.40 50339 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 88.221.145.40 50341 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 88.221.145.40 50342 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 88.221.145.40 50340 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 ALLOW TCP 192.168.0.219 65.52.108.90 50343 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:11 DROP UDP 7.144.100.93 239.255.255.250 54465 1900 165 - - - - - - - RECEIVE
2017-04-17 07:45:12 DROP UDP 7.144.100.93 7.255.255.255 138 138 214 - - - - - - - RECEIVE
2017-04-17 07:45:12 DROP ICMP 7.144.100.93 7.165.156.217 - - 60 - - - - 8 0 - RECEIVE
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 88.221.145.40 50344 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 88.221.145.40 50345 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 88.221.145.40 50346 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 88.221.145.40 50347 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 104.106.125.79 50348 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 104.106.125.79 50349 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 88.221.145.40 50350 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 13.107.4.50 50351 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 13.107.4.50 50352 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 13.107.4.50 50353 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:12 ALLOW TCP 192.168.0.219 13.107.4.50 50354 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:13 ALLOW TCP 192.168.0.219 212.131.108.154 50355 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:13 DROP UDP 7.144.100.93 239.255.255.250 54699 3702 684 - - - - - - - RECEIVE
2017-04-17 07:45:13 ALLOW TCP 192.168.0.219 104.106.125.79 50356 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:13 ALLOW TCP 192.168.0.219 104.106.125.79 50357 443 0 - 0 0 0 - - - SEND
2017-04-17 07:45:13 ALLOW TCP 192.168.0.219 88.221.145.40 50358 80 0 - 0 0 0 - - - SEND
2017-04-17 07:45:13 DROP UDP 7.144.100.93 7.255.255.255 138 138 214 - - - - - - - RECEIVE
2017-04-17 07:45:13 ALLOW TCP 192.168.0.219 88.221.145.40 50359 80 0 - 0 0 0 - - - SEND0 -
I solved this by setting sharing options (no Firewall settings were needed):
Go to Control Panel => Network and Sharing Center
On the left, click on Change advanced sharing settings
Expand the network profile your TeamViewer VPNetowrk is in (probably Public profile)
SOLVING POINT: In sub-section File and printer sharing choose Turn on file and printer sharing
(optional but security) As you may be on more public networks, not just TeamViewer VPN:
For security reasons you should also set this in that network profile:
Network discovery => Turn off network discovery
Public folder sharing => Turn off Public folder sharing (...)
Password protected sharing => Turn on password protected sharing
If you can, choose the best encryption you can (probably 128bit)source:
https://serverfault.com/questions/626233/teamviewer-vpn-blocked-by-windows-firewall/723744#723744
1
