Adding teamviewer on ubuntu to account using command line
I am trying to add a ubuntu pc to my groups.
What i am doing now is the following:
sudo apt install teamviewer-version.deb
sudo teamviewer setup
The problem i have with this is that i have to manually responed to some queastions.
I tryed to script it by using echo but than the setup go's in a loop.
Has anyone a idea on how to automate this in ubuntu 18.04?
Kind regards,
  • Vatsilidis
    Vatsilidis Posts: 655 ⭐Star⭐
    this is a "How to stop the loop script in terminal"  known fact.
    It is easy if you add a few lines of code for send the ctrl+c (SIGINT) signal to bash.
  • Thank's for your response but i can't use that option because it would kill my script and thats is somthing i really don't want.
