Windows 8.1 PC stuck on remote computer screen
My Windows 8.1 PC just stuck sometimes on remote computer screen. Is there any optoon to disable "Hardware Acceleration" in TeamViewer? I remember Google Chrome Browser had a similar problem but I was able to fix it by disabling hardware acceleration in Chrome settings.
  • @JeanK, Let me check. Hope it's will work. BTW, why it's working If I disable the Hardware Acceleration ? And Why not working If Hardware Acceleration is on my PC?
    JeanK Posts: 5,151 Senior Moderator
    Hello @greenitsolution
    According to our engineers, disabling hardware acceleration will change the screen grabbing method. In some cases, it successfully troubleshoots issues.
    French Community moderator
    👉 Have you already tried out the new TeamViewer user interface? Do you want to give feedback? 👈
    ✅ GREAT - Go Ahead!
