Unattended access from PC to Android
I'm trying to set my Samsung 10 so that I can control it from my PC without havingto authorize on the phone every time.
Any suggestions?
Adam
    Hello @adam-digital-ea
    Thank you for your message. ?
    You need to install TeamViewer Host on your mobile device. You can download it via this link or directly from the Play Store.
    After this, you will be asked to assign your device to your account. Once you have done this, you will be able to connect via unattended access from your computer to your mobile device. ?
    I hope this could help. ? If not, do not hesitate to ask your questions here.
    Cheers,
  • oneiltech
    oneiltech Posts: 3 ✭✭
    HI Jean -
    Is there a way to allow unattended access to an android devices for multiple users?
    Thanks,
    Greg
