iPhone Keyboard
Hi, I cannot find a way to get the keyboard to go back down after I have finished typing. It's as if the button to bring it back down is behind the actuasl keyboard, or there should be a button on the keyboard to make it move down. Am I missing something?
Thanks!
Hello @sammy22
The button to the top right will minimize the keyboard as well as the top toolbar ?
Hope this helps!
Josh P.
Senior Community ModeratorDid my response answer your question? Help out others and select it as the Accepted Answer
5
omg! I always thought that was an eject button for the drive!!! Thanks!
Hello @sammy22
You are right! It definitely looks like that ?
As it turns out, we do not appear to have any articles for the iOS/Android toolbars, as we do for Windows and MacOS - We can look in to adding these to our Knowledgebase, to assist with such queries in the future.
Thanks again for the feedback ?
Josh P.
