Using teamviewer from mor than 3 PCs
frippe1970
Posts: 2 ✭✭
I'm using teamviewer from three PCs now using the single user business plan. To which businesplan do I need to change for one or two additional PCs to work from?
Thanks for your
Hi @frippe1970
For this scenario, you will need to upgrade your license to a Premium plan. This is the next bigger license and allows you to work from more devices. The Premium license is a one-user license. That means concurrent sessions from more than one device are not possible.
For more information, please have a look at What TeamViewer license do I need?
Thanks and best,
Esther
Former Community Manager
