"Your partner rejected your connection request"
I connected successfully to my Samsung Tab, then using the remote control i updated the Team Viewer Host on the remote device, after that i got discoonected and now every time i try to start a new session a meesage appears ""Your partner rejected your connection request"".
Its really annoying since its very difficult to reach the remote device.
Any suggestions to solve this issue?
Is there still no solution to this?
I need this to work to support my (half-blind) father's tablet. If I can't fix things for him, he can't use it.
Same problem with Lenovo-TAB-P10-TB-X705L
Hi @rampe , @HappinessMeter , @Tim1023
I believe that this has been solved already and you can see how to solve it and you in this easy-reading post. It seems that this is just a matter of adjustments.
Thank you and best regards
