armv8 64bit TeamViewer build ?
Tried to run TeamViewer armv7 32bit build on an armv8 64bit device using the package for the Raspberry Pi:
* https://download.teamviewer.com/download/linux/teamviewer-host_armhf.deb
I can view the display but the keyboard/mouse doesn't work - i.e. the session is in view-only mode.
Any known fixes/workarounds for this?
If not, any idea when an armv8 64bit build will be available?
  • chatfipachatfipa Posts: 3
    The armv7/32-bit build is working on armv8/64-bit now
    There's a missing dependency which was resolved by installing another package.
  • Dutchman0Dutchman0 Posts: 1
    currently using bpi-m64 aarch64 sbc and am interested in the solution that you were able to make work on the armv8 64 ..
    thank you
  • 2017-08-14-ubuntu-16.04-mate-desktop-beta-aarch64-bpi-m64-sd-emmc.img
    # dpkg --add-architecture armhf
    # apt update
    # apt-get install libxtst6:armhf
    # dpkg -i teamviewer-host_armhf.deb
    # apt install -f
    # teamviewer --daemon enable
  • OMG YES THANK YOU. 4 hours later, and ONLY you found the niche problem.
    It turns out you need the libxtst6:armhf dependency.
  • zjacobszjacobs Posts: 1
    Not recommended.  This didn't work for me and it completely broke apt.
