Can't control my phone with QuickSupport HUAWEI
Takeshi-dayo
in Mobile
Hello. This terminal only supports screen sharing, I want to fully control the Android terminal remotely. Information about the device HUAWEI MATE 9 MHA - L29 android 7.0 Please enable this.
1
Try installing the Android Host instead of QS
Bart Lanzillotti
We Do IT USA
www.wedoitusa.com0 -
I tried putting teamviwerHost, but I can not control it, but if add-on does not match the version, I get an indication and ask for uninstallation of add -on.
TeamViwerHost version 12.2..6961HM0 -
Can you elaborate on this part please " but if add-on does not match the version, I get an indication and ask for uninstallation of add -on. "
Bart Lanzillotti
We Do IT USA
Not compatible with current system version0
Ok, then unfortunately I suspect that the Huawei device you are using is like my Dad's Xoom and does not support remote control.
Bart Lanzillotti
We Do IT USA
please check this thread for further information and download the app from Google Play.
I hope, this will solve the issues :-)
All the best, Esther
Community Manager0 -
I have the same problem with my Huawei Y560 model.
Anyone helps ?
