Can't control my phone with QuickSupport HUAWEI
Hello. This terminal only supports screen sharing, I want to fully control the Android terminal remotely. Information about the device HUAWEI MATE 9 MHA - L29 android 7.0 Please enable this.
  • bartlanz
    bartlanz Posts: 324 ✭✭✭
    Try installing the Android Host instead of QS
    Bart Lanzillotti
    We Do IT USA
    www.wedoitusa.com
  • I tried putting teamviwerHost, but I can not control it, but if add-on does not match the version, I get an indication and ask for uninstallation of add -on.
     TeamViwerHost version 12.2..6961HM
  • bartlanz
    Can you elaborate on this part please " but if add-on does not match the version, I get an indication and ask for uninstallation of add -on.  "
    Bart Lanzillotti
    We Do IT USA
    www.wedoitusa.com
  • Not compatible with current system version
  • bartlanz
    Ok, then unfortunately I suspect that the Huawei device you are using is like my Dad's Xoom and does not support remote control.
    Bart Lanzillotti
    We Do IT USA
    www.wedoitusa.com
  • Esther
    Esther Posts: 3,222 Community Manager
    please check this thread for further information and download the app from Google Play.
    I hope, this will solve the issues :-)
    All the best, Esther
  • I have the same problem with my Huawei Y560 model.
    Anyone helps ?
Howdy, Stranger!
