Remote connection does not show a normal desktop
Computer A & B: Windows 10, Teamviewer 15
Plz check the screenshot from A, the machine B tab appears on the left corner, which means I think the connection is made, but B's screen doesn't show normally, I mean there should be icons with cursor out there. It's hard to say that is a black screen, just the display is abnormal
A > B: failed,  B > A: works
    Hello @Anondot,
    Thank you for your message. ?
    It's possible that is it a display lag/bug. ?‍♂️
    Could you please try to refresh the screen with the refresh button?
    You will find it in the toolbar under View: Remote control toolbar - View
    I hope this could help. ?
  • Anondot
    Anondot Posts: 2
    Refresh screen cannot solve my issue as I tried,thx
