Hardware Bridging?
I'm using a USB device on one computer that I would like to also be able to use on the TeamViewer computer I am connecting to. Is this possible?
    Hello @kingmurphy29,
    Thank you for your message. ?
    I'm not sure if this is what you have asked, but with the TeamViewer VPN, you can access a USB stick that is connected to a remote computer.
    You will find all the information you need in our Knowledge Base article here: About TeamViewer VPN
    I hope this could help. ?
    Best regards
  • kingmurphy29
    Let me explain further...
    Let's say Computer A connects to Computer B. Computer A had a USB microphone connected to it that is used with a piece of recording software. Will (or can) that USB mic be recognized as a device on computer B?
    @kingmurphy29 Unfortunately, what you describe is impossible to do with TeamViewer. ?
    It is not possible to mirror microphones on a remote device via TeamViewer.
    Best regards
