TeamViwer HOST Security
Hello please your help with this please
I need to apply a password to the settings menu but apply it to a Security Policy and then apply it to all my associates at once. I found the way to do it (see photos) but manually, I could not do it from a security policy.
I would also like to know if I can leave the option to manage additional passwords for unattended access gray, so that no one even with the key can add additional password. (view photo)
Screen Shot 2020-04-13 at 16.17.38 PM.pngScreen Shot 2020-04-13 at 17.08.11 PM.pngScreen Shot 2020-04-13 at 13.48.48 PM.png
    Hello @ccortesfsg,
    Thank you for your message. ?
    The TeamViewer policy parameter that will protect your settings with a password is Changes require administrative rights on this computer
    You can find this parameter in the list when setting up your policy. More information here: TeamViewer policies - Options, attributes and values
    By protecting people to enter the settings, you will also prevent to add additional passwords.
    I hope this could help. ?
    Cheers,
  • ccortesfsg
    ccortesfsg Posts: 6 ✭✭
    Thank you Jean,
    Finally the unique solution was that applied manually a password to all associated, I probed all option that you recommend can but not lock the panel setting.
    Cristian
