Lock remote compute isn't working
PX-cvgordy
PX-cvgordy Posts: 1
edited January 2023 in General questions
I have enabled "Lock Remote Computer" to Always on all devices and it never locks the computer. Can anyone provide any suggestions or ideas on why this is the case?
I want to make sure all of my desktops are always locked at all times unless actively being used and I had this working in **Third Party Product** without issue. I assume Teamviewer has the same ability however I have not been able to get it to work.
  • bartlanz
    bartlanz Posts: 315 ✭✭✭
    Will they lock from the ribbon if you click Actions > Lock > Lock Now?
    Also on that menu do they lock if you check off the Lock at end of session check box? Is the check box checked when you look at the menu?
    What version of TeamViewer are you using?
    Ribon > ActionRibon > Action
    Bart Lanzillotti
