Teamview Window is not displayed correctly on IPAD PRO
kwekcs
Hi, I tried to login to my laptop on the IPAD PRO and the teamview screen is extremely small .. what should be changing to get it to fit correctly? I tried different resolutions and it did not work at all.
1
Do you find something to fix that?
How did you fix this?
