Sign out of TeamViewer Desktop after inactivity
Hi there,
I use authy to login to TeamViewer on my own desktop (using Authy as extra security). From there I connect to 4 different PCs. I often forget to sign out (or exit) TeamViewer on my desktop in spite of best intentions.
Question: Does anyone know if there is a setting which will automatically sign me out (or even exit)  TeamViewer on my desktop after a period of inactivity?
Michelle
    Hello @michellepace,
    Thank you for your message and welcome in the Community! ?
    You can set this up directly in the TeamViewer options of your computer.
    1. Open TeamViewer on your computer
    2. Go to Extras → Options
    3. Go to Advanced
    4. In Advanced settings for connections to other computers, place the arrow on the timing out period you desire
    I hope this could help. ?
    Cheers,
  • michellepace
    Thank you Jean for your reply. However, this is not actually what I am after. On my PC I log into TeamViewer and I use the APP Authy. I then have access to a variety of machines. Should I leave my PC unattended, these machines then become at risk.
    What I am looking for is for *me* to be logged out of TeamViewer upon XX minutes of activity such that my password and authy code would be required again. Does such a setting exist?
  • michellepace
    Thanks Jean. That is quite a big sercurity hole, but very simple to solve. Could you please suggest it as a feature request?
    Even windows will "lock" after a certain amount of inactivity.
    I checked and this function already exists for our Management Console (https://login.teamviewer.com/).
    You will be automatically logged in after a certain amount of time. But not for our TeamViewer client version.
    I forwarded your request to implement this for the client version as well. ?
    Thanks again for the discussion - take care and stay safe! ?
  • Thomas_MT12
    Thomas_MT12 Posts: 1
    dear all
    i see this message is from may 2020
    already improvement made for professional paid users?
    i really need this as i always forget to logout
    i have around 10 computer in my netwerk i use and i now there are definitly 50 desktops with teamviewer open and acces to all 10 computers
    please let me know where i can change the setting that teamviewer logs out on your desktop application after for example 1hour of inactivity
  • Alvaro_at_DGI
    Alvaro_at_DGI Posts: 3 ✭✭
    It's been three years since this request, and I am wondering if this feature will ever be implemented. The OP is right, this is a security hole. The desktop client should ask daily to reauthenticate using Two Factor authentication. To many machines can be at risk, if a PC is left unattended, or if a TA gains remote control of a user machine through social engineering, etc. Very common this days.
