HOST Macbook pro does not enter sleep mode when teamviewer is remote controlling a guest
I am using latest Macbook pro late 2016, when I start a remote control from macbook, even I am inactive for enough time, the macbook does not enter into sleep mode.
Is it a normal behaviour? How to turn this feature off?
Many thanks.
This is normal behaviour. If either of the systems involved enter a sleep state, the TeamViewer session will end. For this reason, TeamViewer prevents the remote system from going to sleep until the session is closed.
Bart Lanzillotti6
I assume this is intended due to the fact that there has to be some sort of back and forth traffic to keep the connection alive, therefore not technically allowing enough idle time to initiate sleep. You can look in the settings/options for the inactivity timeout and set that to 20 minutes (for example) which will allow it to force close the connection and 'reset' the idle timer on the system hopefully allowing that to sleep after the OS timeout passes.
--Edit--
I believe the inactivity settings you need to adjust are from the system you are connecting FROM. Although setting it on both would probably be best.1 -
Bart Lanzillotti6 -
TeamViewer continues to prevent the Mac from going to sleep even after the connection is closed. That doesn't make sense.
