Remotely setting host password
Ziggy
Ziggy Posts: 5 ✭✭
   I use a RMM (Ninja by name). They can't for the life of them keep their TeamViewer access running properly. You are supposed to be able to set the host password in Ninja and have it "sync" to the TeamViewer Host. Great concept but they have never been able to get it to work properly. The other day it colaplsed completely and I have pretty much lost access to all my hosts because it keeps asking for a password that I don't know. So... does anyone know how to set the TeamViewer Host password via a remote script I can run with Ninja (until they screw that uo too)? or next best case add an additional password?
    Hello @Ziggy,
    Thank you for your message. ?
    To get the right script as fast as possible, please contact our support directly. Our engineers will provide you with a solution. ?
  • ArchMaple
    ArchMaple Posts: 1
    @JeanK wrote:
    Hello TellDunkin
    Thank you so much for your great information, It is too useful for me.
