I know I can change the color of the mouse pointer but how can I change the size?
I have changed the size on the pc I am viewing but it is too small on the viewer PC
Thanks for any advice
Bob
[ SOLUTION ] The standard Win setting to change the cursor size does not work.
BUT there is another setting called Mouse Properties that opens a separate smaller window: There you find under the tab Pointers, the Scheme > Magnified that increase the size of the pointer during the TeamViewer remote session.
+1 for this feature. I'm using a 4K monitor and the cursor is ridiculously small. Often I have to bring it to my secondary display in order to be able to track it.
Turning on the mouse pointer trails isn't a perfect solution, but it helps.
This needs to be sorted. Very difficult to use otherwise. Making me look for alternative products.
Teamviewer is almost unusable due to the small size of mouse pointer. I just read that this is not adjustable. Unfortunately i'm going to have to cancel my Teamviewer membership and go with another remote access service.
Is there any improvement on this topic ?
I have big difficulties to see the remote computer pointer .
Hello @BobbyTee
The mouse pointer is a fixed standardized item.Unfortunately, there is no possibility to modify the size of it.
Best regards
