Teamviewer 13 not connecting in Ubuntu 18.04 Login Screen
I installed Ubuntu 18.04, and I noticed that in the Login Screen Teamviewer (teamviewer_13.1.3026_amd64) is not connecting.
However, when I log in then Im able to use Teamviewer.
I didn't have this issue with Ubuntu 16.04 and teamviewer_13.1.3026_amd64.
  • beduoin
    beduoin Posts: 1
    I'm having the same issue. I can log in, but won't connect to host.
  • Smeg
    Smeg Posts: 1
    I get a similar issue. After reboot, I cannot connect via Teamviewer.
    Following manual login, Teamviewer is able to connect at the login screen until the next reboot.
  • dtstanton
    dtstanton Posts: 11
    Same here. On Ubuntu 18.04 bootup, Teamviewer 13 does not start. Starts after login.
  • Esther
    Esther Posts: 3,528 Community Manager 🌍
    Hi there, thanks for the hint. I removed beaver from the filter.
    Best, Esther
  • dtstanton
    dtstanton Posts: 11
    That worked. Thank you!
  • LowKi
    LowKi Posts: 1
    That workaround link is 404.. can someone transcribe post relevant information?
  • Hi,
    Links are 404 because Teamviewer forum didn't allow me to write full urls as in their content have beaver word.
    https:// linuxconfig.org/how-to-install-teamviewer-on-ubuntu-18-04-bionic-**bleep**-linux
    Substitute the **bleep** by beaver word.
  • <TL;DR>
    sudo gedit /etc/gdm3/custom.conf
    Uncomment this line in custom.conf file:
    WaylandEnable=false
    and Reboot.
  • 905jay
    905jay Posts: 1
    I can confirm with TeamViewer 14 and Ubuntu 18.10 that this works
  • Jocafi
    Jocafi Posts: 1
    Thanks bobgutierrez.
    It solved the problem on my Ubuntu 20.04 LTS and TeamViewer 15.6.7
    Best Regards,
    Jocafi
  • Kylian01
    Kylian01 Posts: 31 ✭✭
    this problem is not only un Ubuntu i have it on
    Arch
    Manajro
    Ubuntu
    Debian
    Fedora
  • This works for Ubuntu 20 And Teamviewer 15.
    @bobgutierrez wrote:
    <TL;DR>
    WaylandEnable=false
    and Reboot.
