Uninstall Old version Teamviewer
Hello! Started deploying a new version of the TeamViewer host by SCCM. Using the query SCCM, I found a lot of old versions of TeamViewer 11, 12, 13, 14. I Tried to delete it using msiexec /x, uninstall.exe /s, deleted registry branches. But still the new version is not installed, there are some remnants. Using the tool from Microsoft install and uninstall Fix was able to completely remove the old versions, but this is not an option, since there are many computers. Is there a universal tool for deleting Teamviewer or a script? Thank you!
    JeanK Posts: 4,526 Moderator
    Hello @Mikushkin-a,
    Unfortunately, we do not have any universal tool for deleting TeamViewer.
    Best regards
    French Community Moderator
    Hello @Mikushkin-a,
    Thank you so much for sharing your solution! ?
    We will make sure to share it with any customer/user that has this problem. ??
    Best regards
  • S_Hedemand
    S_Hedemand Posts: 1
    This usually works:
    for /f "tokens=4 delims=\" %a in ('dir /b %SystemRoot%\installer /s ^| find /i "TeamViewer.ico"') do start /w MsiExec.exe /X%a /qb-
    If you put it in a .bat file, use %%a instead of %a
