How to check back previously partner ID ?
hi there,
Is there anyone know how to check back previously Partner ID record ?
Currently i try to login few partner ID but some partner ID was unable to join back, So i wonder is it i key in wrong partner ID. and i wish to know how to trace back the partner id record. thanks.
    Hello @leonardo83,
    You can find the record of incoming connections in your File Explorer in the following path:
    C:\Program Files (x86)\TeamViewer
    in the file Connections_incoming.
    I hope this could help. ?
    Best regards
