removing of signin info into computer & contacts
How do I remove the sign info into computer & contacts?
Best Answers
Are you looking to hide the window completely or make it so you don't need to log in at all to see the list?
Bart Lanzillotti5 -
Ok, Click your name at the bottom of the screen (yellow aarow) and it will bring up the window in the right of the pic. Click your name at the top of that window (red aarow) then click sign out.
Again, You want to delete the pic
Bart Lanzillotti8 -
Once you are logged out, you do not need to delete the pc from your account. If you want to, you can log back into your computers and contacts list on that pc or another one, then right click on the PC in the list, then hit the gear in the upper right hand corner and click delete. that will remove it from your Computers and Contacts list.
Bart Lanzillotti5 -
Sorry I miss-read your post, I thought you said PC, You said Pic, you need to go back and click the three dots in the upper right of the post, then edit and delete the pic from the post.
Bart Lanzillotti5
Bart Lanzillotti5 -
Have a unit that has my sign into contacts wish to remove it from the remote computer so they don't have my computer and contacts and sign in
Ahhhh a third option Ok so if you open TeamViewer. Click your picture (Red Aarow) then in the upper right hand corner is a gear (No Aarow) click that then sign out. This should bring you back to the login screen for Contacts and Computers. Which will prevent others from seeing them.
Hope that helps
Bart Lanzillotti1 -
I have found if you change your pass word it will remove the sign in info.
First, Delete that pic, it shows your info. I'll get you a screen shot of the old screen with instructions on how to do it.
Bart Lanzillotti2 -
Bart Lanzillotti8 -
how do I delete the pic?
got it done on the delete
2 -
Bart Lanzillotti5 -
Bart Lanzillotti5
