Teamviewer hangs with "Pasting from ..." Message on host
mbohu
mbohu Posts: 5
We are testing TeamViever and every time we log in the computer hangs with the message "pasting from..." There is no solution posted here in the community, there is absolutely no support and the only option which was suggested in another post (to turn off "clipboard synchronization") does not exist in the preferences in version 13.
Is this tool working at all for anybody?
We used older versions in the past and they worked great. But this version seems to be completely useless.Untitled 13.png
  • dpgvan
    Seeing the same issue. Had to finally disable File Transfer from host and client to make it work. Happens only when two Mac systems are used for host and client.
  • coltonidle
    Is there any solution to this? I'm on a mac and I force quit Teamview, and I still see this popup. No other computers on my account are online.
    Version: "TeamViewer 15.4.4445 is currently the newest version available."
    Am I being hacked?
  • ale206
    ale206 Posts: 1
    It worked for me.
    From the mac I had to go to Preferences > Advanced > Access Control > change the dropdown to Custom Settings > Configure... > Deny Transfer files and File transfer using the file box.
