Edge-management installation error
We use our own Yocto Rocko image for our devices with ARM Cortex - A9 and want to provide Teamviewer IoT for out customer. After we have installed some missing packages for Teamviewer IoT on the OS, we now want to install the Edge Management. We would be very thankful or help.
root@santino-lt:~# teamviewer-iot-agent start edge-management
Edge Management is not installed. Do you want to install it? (Y/n) y
Edge Management is enabled.
Connecting to download.teamviewer-iot.com (52.85.32.26:443)
wget: error getting response: Connection reset by peer
Hi mircea_c,
the "ca-certificates” packet is installed. The question is which certificates are required exactly and where must they be located? Are there any other possible causes of the error?
