TeamViewer 11 in Linux Mint 19 Xfce
A preliminary search has not shown me a solution to my current problem: I need to install TeamViewer 11 on Linux Mint Xfce 19, 64-bit. The regular install instructions have never worked, on account of TeamViewer needing the libpng12-0 package in i386 architecture. I'm thinking it also needs wine-stable? I tried installing those packages first, and it recognized that I had installed the libpng12-0:i386 package, but when I try to start TeamViewer, nothing happens. Could the TeamViewer team please update the instructions for installing TeamViewer so that it's painless on Linux? What am I missing to finish the install on my machine?
Thanks for your time!
emptythevoid Posts: 8
Okay buddy, I've got a procedure for you to try. You may need to purge out your old teamviewer install before trying this.
For whatever reason (systemd?), even after I did all the steps, it didn't work until after I rebooted.
10
The libpng package required by old versions of Teamviewer is no longer in Ubuntu repositories. I got it from here:
http://ftp.us.debian.org/debian/pool/main/libp/libpng/libpng12-0_1.2.50-2+deb8u3_i386.deb
And installed it by doing
sudo dpkg -i ./libpng12-0_1.2.50-2+deb8u3_i386.deb
See if that helps.
@emptythevoid: Maybe you didn't read my post, or I wasn't very clear. I already installed that exact package exactly the way you said, and it didn't help. I need further ideas, I'm afraid.
Ah, sorry, I was a bit hasty.
I'm spinning up a Linux Mint 19 XFCE VM right now. If you try to launch Teamviewer from the command line, do you get any error messages?
I get the following:
Init...
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
Then I get my prompt back, and nothing else happens. I don't see TeamViewer come up.
Do you recall if you installed the 64-bit-only version, or the 32-bit/64-bit multiarch version?
That worked, oh joy! I got all the way in, and was able to TeamViewer into another of my computers. Thanks so much!
Thanks for getting back! It's made my day that I was able to help.
Let me investigate that pgp package. Maybe I had a typo.
Edit: Yep. It's supposed to be libgpg-error0:i386 Whoopsie. I'll update my notes. Thanks for pointing it out.
It helped me a lot. I was stucked for two days trying to run TV11 on my linuxmint 19.
Excellent! Glad to hear it helped! That makes my day
I'm really glad to hear that fixed it for you! That makes my day!
It's not possible to install procedure nr 7 (wget http://security.ubuntu.com/ubuntu/pool/main/f/freetype/libfreetype6_2.6.1-0.1ubuntu2.3_i386.deb), it gives a 404 not found error. Where to find this package? Thank you very much in advance. Without this, seems I can't continue with the installation.
Here is the updated link
http://security.ubuntu.com/ubuntu/pool/main/f/freetype/libfreetype6_2.6.1-0.1ubuntu2.4_i386.deb
Step 8 on pastebin should be
8.) ar -x ./libfreetype6_2.6.1-0.1ubuntu2.4_i386.deb
This is how I got it to run on Linux Mint 19
