TeamViewer for macOS "Send key combinations" not working Mac to Mac...
deejinoz
deejinoz Posts: 34 ✭✭
Client OS, both ends: macOS Catalina 10.15.6
TV version, both ends: TeamViewer 15.7.6 (paid)
Issue: Actions -> Send key combinations is ticked but greyed out. Sending of key combinations, such as COMMAND + TAB, for application switching, brings up local application switching, not remote application switching and COMMAND + SPACEBAR brings up Spotlight Search locally not remotely.
Other points:
Some Finder key combinations do seem to work such as COMMAND + H and cut, copy and paste.
Behaviour appears to be the same whether in windowed of full screen.
Any suggestions before I open an actual support case?
    Hello @deejinoz
    We are aware of keystrokes issues in a macOS context. I recommend you to open a support ticket to get individual help: https://support.teamviewer.com/a/
    Best regards
  • Fieldworkstudio
    We are having the exact same issue here. Also the scrolling is completely screwed up. Can someone please help us out?
    Modifier keys from mac to mac don't work in Pro Tools. We use a program called soundflow for custom key commands and for example the command "CTRL+OPTION+CMD+P" doesn't do anything.
    @JeanK
