Can't add user, errors out
When I try to add a user, it errors out with this error:
Sorry, an error occurred while processing your request.
mWnZJdPaqfu-3-1-2A-VrD
This is a corporate account, I just used the AD connector but it didn't pull everyone automatically, so I want to add manually.
    Hello @champton,
    We have been notified about this issue in the past days.
    In some cases, the issue is fixed only with logging out and in again from your Management Console. Could you please try this and try the operation again?
    I hope this could help. If not, do not hesitate to contact our support by opening a ticket via the following link: Open a ticket now!
  • champton
    champton Posts: 4
    Okay, so that fixed it (I think), running into another problem:  All the accounts that didn't come in on our Management Console have accounts that were created, according to Teamviewer, but they aren't nested under our company.  Is there any way to fix this that doesn't involve me emailing everyone the join link?
    Hello @champton
    Now that you fixed the issue within your Management Console, you can do the AD-Connector process again. It will add your users without any problems.
  • Groot-mike
    Hi We have the same Isue also on a corporate acount cant add any users as soon as we open user management we get the following error An unexpected error occured: mWitTQvjbWi-3-1-30-gXy we have tried signing out evem diferent browsers and workstations
    to no avail
    Hello @Groot-mike
    Could you please log in and out and try once again, please? It should be working now.
    Best regards
  • Groot-mike
    hi thanks i just tried that same error
    thanks
    Hello @Groot-mike,
    I have forwarded this issue to our dedicated team.
    I followed-up this issue via private message.
    Best regards
    Hello @Groot-mike,
    The issue should be fixed now.
    Could you confirm?
    Best regards
  • insman
    insman Posts: 1
    edited August 2021
    Also getting this error now.
