**bleep** Default Permissions?!
I just installed Teamviewer & started first session with a tech support from a company I bought one of their services,while he was on the phone.
when the session ended,I started exploring the Teamviewer options,,changed the language to English and saw this the Default Setting was: Full Interaction with FlieTransfer:Allowed & RemotePrinting:Allowed!!!
Which seems insecure and **bleep** to be a default setting!
so my question is Why on earth is this the default setting?
and how do I know if any files/folders from my computer were transfered or printed by the remote person who had access?!
Thx
    Hello @digitalmg
    You are correct - the default setting of TeamViewer gives to the user the full feature package and capabilities of the software with no restrictions. It is in the power and responsibility of the user to set up restrictions if needed.
    If you want to make sure no one is transferring files to or from your computer, please follow these instructions:
    1. Open TeamViewer
    2. Go to Extras, click on Options
    3. Go to Advanced
    4. Go to Advanced settings for connection to this computer, in the Access Control menu, Select Custom settings. Click on Configure... and set Transfer files to Denied
    5. Go to Advanced settings for connection to other computers, in the Access Control menu, Select Custom settings. Click on Configure... and set Transfer files to Denied
    I hope this could help. ?
    Best regards
  • digitalmg
    I already made these changes,but I dont think this should be the default setting,or at least show an alert or warning that this is the setting and ask the user to accept it or customize it.
    Anyway,is it possible to see if any files or folders were transfered during the session?I tried the log file but it is not humanly readable.Any simple way to know if anything was transfered from my laptop?
    Hello @digitalmg
    Thank you for your opinion. It is always valuable feedback to improve our product. ?
    The logs are the only location where you can get in-session information.
    There is, unfortunately, no simplified log file version.
    Best regards
