macOS 11 Big Sur Initializing Display Parameters Hangs Resulting in Black Screen
title says it all.  anyone using big sur beta and having this issue?  Thanks!
    Hello @riddlemeright
    macOS 11 Big Sur is not officially supported yet. Therefore, there still can be issues/bugs when using TeamViewer with this OS.
    You will find all the information you need regarding officially supported OS in our Knowledge Base article here: Compatibility with macOS
    Our dedicated team is currently working on it and we put our efforts together to officially support macOS 11 Big Sur as soon as possible.
    We are sorry for the inconveniences caused.
    Best regards
  • riddlemeright
    I'd be grateful to test a beta.  I have worked in IT for many years and would be happy to provide feedback.
