Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Henagon
Cloning Teamviewer accounts and IP addresses to fool work employers...
So someone....and I bet I know who....has somehow cloned my home laptop Teamviewer account so that she's makiing iit seem like I'm logging onto my work computer from home while I'm actually clocked in at work. How do I prove that she has set this up? I already have a screeshot of her being on my computer but that's not enough.
I'm gonna get fired tommorrow. Any quick help?!!!
Highlighted
Posted by TeamViewer Star
TeamViewer Star
Re: Cloning Teamviewer accounts and IP addresses to fool work employers...
Hi
This is not an answer, because I do not think that this is a question for the community.
I apologize for that.
If anyone has been able to use your TeamViewer account, it means that he had access to your credentials. If used them from a different computer, the request for authorization of the device is activated by the attached mail box, to which you had to have access, or the both of you had.
Here you can find the input and output TeamViewer log: https://www.teamviewer.com/it/help/51-where-do-i-find-the-teamviewer-log-files
You should also refer to the Windows event handler (Event Viewer - if you use this OS) are indicated all authentications.
Good luck.
Domenico Langone
MCSD: App Builder
Highlighted
Posted by
Henagon
They had access to my computer itself!
Highlighted
Posted by
Electron
Did you get fired ?
