TeamViewer meeting participant breaking connection every few minutes.
Announcements
Enjoy your weekend!
If you want to read our latest blog post, click here.
Highlighted
Posted by
Henagon
I have a problem with meetings addon to a TeamViewer (latest stable version). I am using TeamViewer 13 under corporate 6 channel license.
Problem is that every few minutes, sometimes under a minute. My TeamViewer meeting connection to a remote session breaks. It looks like I am kicked out and I can connect back very fast. It is very annoying - I speak to somebody on the other side, session disappears, I open it again and after few seconds I can speak again.
I know first thing to blame is a network itself, but I am running 20Mbsp symetric fiber connection. Other side is also on fiber and even with much higher speed. Its a meeting between office in Poland and Canada. I had no issues like this before summer. I have checked it on 2 computers and strangly at first I had only problems with one, but after a week it is on both.
I haven't had any problems with TeamViewer to a remote computer as a support request. It never breaks. I have noticed session breaks more easly if more participants (eg. 4, all with video) are connected. Maybe it is related to a CPU stress it gets from these sessions but on the other hand it's i7 so should handle 4 video streams (and it did in the past).
Please help me solve this. Can't work like this. If you need any log or debuging on my end please let me know. I need to fix this.
1 Reply
1 Reply
Highlighted
Posted by Moderator Moderator
Moderator
Re: TeamViewer meeting participant breaking connection every few minutes.
Hello PiotrBoryszek,
Could you please send me a direct message with your license number and your e-mail adress ?
I will create a ticket for you so our support can investigate on the issue.
Thank you in advance for your reply.
Jean Kinzler
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
