Highlighted
Posted by hamzamaal
Henagon
Teamviewer 14 Beta 14.0.8346 not ready. Please check your connection
Something weird is going on. I had TV 13 installed and working fine. I installed TV 14 beta, now getting the error no connection.
I uninstalled TV 14 and reinstalled TV 13, and the connection works fine after re-install.
However I have installed TV 14 on my remote home system and will need to re install it there in order to connect as my laptop version is below the TV 14 Beta.
I am away for the next week and need to connect to this remote machine and cant reinstall TV 13 on windows without uninstalling  first (Tried via my Android phone and could connect on the same wifi connection) which means I cannot access this machine.
The remote machine is windows and my laptop is Mac OS Mojave.
Please help
Highlighted
Posted by Moderator Moderator
Moderator
Re: Teamviewer 14 Beta 14.0.8346 not ready. Please check your connection
Hello hamzamaal,
I recommend you to restart the TeamViewer service.
-Execute "run", type "services.msc" and press OK
-Now find TeamViewer, and restart it by doing a right click.
Then, restart the TeamViewer application. It should work again.
Best regards
Jean Kinzler
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
Highlighted
Posted by hamzamaal
Henagon
I am on Mac OS not windows. I have alredy check my /etc/hosts file, cleaned out and flushed my dns cache, and restarted the machine, but no luck.
Highlighted
Moderator
 Hello again,
Please delete the plist file of TeamViewer on your system.
You will find this file under:
Finder | Home directory | Library | Preferences. Here, delete all plist entries of TeamViewer.
Please also remove all entries starting with "com.TeamViewer" from
<home>\users\USERNAME\Libary\Preferences\
Then, install TeamViewer again.
Let me know if this could help.
Highlighted
Posted by hamzamaal
Henagon
Hi Jean
I have deleted the following files as advise, resintalled the TV14 and restarted machine but still the same issue
rm com.teamviewer.TeamViewer.plist com.teamviewer.teamviewer.preferences.Machine.plist com.teamviewer.teamviewer.preferences.plist
I am trying to send the log but I think it is too long or has TV ids so not being accepted.
Highlighted
Posted by hamzamaal
Henagon
Small sample of the log, hopefully it does not have any TV ID's
Activating Router carrier
KeepAliveSessionOutgoing::ConnectSuccessHandler(): KeepAliveConnect to router5.teamviewer.com successful
CKeepAliveClientClient::HandleConnectSuccess: Protocol 8 proxy --
KeepAliveSessionOutgoing::KeepAliveChannelInitialized(): KeepAliveConnection to router5.teamviewer.com initialized
KeepAliveSession::KeepAliveChannelInitialized(): KeepAlive-Connection initialized with ID 0 (IP: 188.172.198.136), SendQueue 13 (13845 Bytes), SendIndex 0, AckIndex 12, RemoteSessionID 67
KeepAliveSession::SendCompleteQueue(): SendQueue: 13 (13845 Bytes), RemoteSession 67 (ClientID 0), Time: 0 ms
IdentifyRequest: ID = 0, IC = 573573, IsTemporaryID = 0, InitiativeGUID = 8203109f-d1d5-42a6-b26f-83e3598ba1d2, CanStoreGUID = 1, MIDHistory = {0x4c32758d40f1_C02SN1YFG8WN_MacVersion|o4c32758d40f1c02sn1yfg8wn<~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~0dd0c5b4e712d7cef7750d93b4e6b006|applemacos024c32758d40f1c02sn1yfg8wn<~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~0dd0c5b4e712d7cef7750d93b4e6b006}, MIDv = 0, MaxSupportedMIDv = 2, RebootHash = {22545736-756a-6e8b-a3df-c**Please do not post TeamViewer IDs**a4}, MIDFlags = 128, MIDForceUpdateFlags = 0, AttractionGUID = 00000000-0000-0000-0000-**Please do not post TeamViewer IDs**00
CTcpConnectionBase[67]::HandleReadError(): Error occured. ClientID: 0 IP: 188.172.198.136 Category: system, Error: 54 (Connection reset by peer)
SecureNetworkConnection::SendCallbackHandler(): [ remoteID: 42 connection: 1 remoteConnection: 0 ], Error: RCommand (Cancel)
SecureNetworkConnection::SendCallbackHandler(): [ remoteID: 42 connection: 1 remoteConnection: 0 ] Resetting connection due to error RCommand (Cancel)
Communication::Messenger::SendAnonymousMessage: error: Could not connect
TVRouterClock Schedule next request in 0 seconds
SecureNetworkHandshake::ReceiveAckCallback: [remote ID: 42, connection ID: 1] errorcode: Cancel(3)
CKeepAliveClientClient::HandleKeepAliveEnded: doing nothing, state = 4
KeepAliveSessionOutgoing::ConnectEndedHandler(): KeepAliveConnection with router5.teamviewer.com ended
CKeepAliveClientClient::StartConnect(): Protocol 8 proxy --
KeepAliveSessionOutgoing::ConnectSuccessHandler(): KeepAliveConnect to router14.teamviewer.com successful
KeepAliveSessionOutgoing::KeepAliveChannelInitialized(): KeepAliveConnection to router14.teamviewer.com initialized
KeepAliveSession::KeepAliveChannelInitialized(): KeepAlive-Connection initialized with ID 0 (IP: 37.252.254.179), SendQueue 1 (1065 Bytes), SendIndex 0, AckIndex 0, RemoteSessionID 68
KeepAliveSession::SendCompleteQueue(): SendQueue: 1 (1065 Bytes), RemoteSession 68 (ClientID 0), Time: 0 ms
CTcpConnectionBase[68]::HandleReadError(): Error occured. ClientID: 0 IP: 37.252.254.179 Category: system, Error: 54 (Connection reset by peer)
KeepAliveSessionOutgoing::ConnectEndedHandler(): KeepAliveConnection with router14.teamviewer.com ended
KeepAliveSessionOutgoing::ConnectSuccessHandler(): KeepAliveConnect to router3.teamviewer.com successful
KeepAliveSessionOutgoing::KeepAliveChannelInitialized(): KeepAliveConnection to router3.teamviewer.com initialized
KeepAliveSession::KeepAliveChannelInitialized(): KeepAlive-Connection initialized with ID 0 (IP: 84.233.235.178), SendQueue 1 (1065 Bytes), SendIndex 0, AckIndex 0, RemoteSessionID 69
KeepAliveSession::SendCompleteQueue(): SendQueue: 1 (1065 Bytes), RemoteSession 69 (ClientID 0), Time: 0 ms
CTcpConnectionBase[69]::HandleReadError(): Error occured. ClientID: 0 IP: 84.233.235.178 Category: system, Error: 54 (Connection reset by peer)
KeepAliveSessionOutgoing::ConnectEndedHandler(): KeepAliveConnection with router3.teamviewer.com ended
Highlighted
Posted by robdupre
Electron
I am on Windows 10 with the same Teamviewer 14 Beta 8346 build. I have the same issue: Not ready. please check connection with a message asking about proxy settings appearing.
Highlighted
Moderator
Hello robdupe,
Did you try to restart the service, as I suggested to hamzamaal ?
Thank you in advance for your reply.
Highlighted
Posted by robdupre
Electron
Yep,
Restarted the service. Cleared the hosts file out. pinged master1.teamviewer.com and get the same results as machines with TV14 which work fine. Checked proxy settings. Firewall seems to have exceptions for TV. All seem fine
Thanks Rob
Highlighted
Posted by BrunelIT
Henagon
I am also getting this across every single install of TV14 - multiple OS - MAc and Windows 10 - and everything from Windows defender to BitDefender. Nothing will make it connect.
If I completely remove TV and remove settings, then reinstall then it will work until the first reboot and then from that point I just get check your connection errors.
It's broken our entire support structure - beginning a roll back to v13.
Highlighted
Posted by luweitest
Photon
I have the same issue. It will pop up the proxy setting window. Uninstall 14 and reinstall 13 will fix it. Proxy not supported?
