Announcements
Remote Control for all devices running Android 7+ is here!
(Incl. Google Pixel series, Xiaomi smartphones, Oppo devices, and many more)
Learn more
Highlighted
Posted by
Photon
Re: Teamviewer initializing display parameters and hangs Version 12.0.71503
There is no access via KVM to this VM?
Highlighted
Posted by
Henagon
When I log in to affected computer I was unable to connect, there is stuck Desktop Windows Manager (dwm.exe) and I have to restart it through taskmanager.
Every time it is similar, on computer I tried to connect and fail taskbar is not responding and i have black background (got image). After forceclosing DWM, background comes back.
Using Windows 10 last build, got Eset Antivirus. Happaned on two different computers same way.
Highlighted
Posted by
Photon
I also go this to work by opening TeamViewer Host on my target machines, clicking on the little lightbulb next to 'Your ID' and using the secondary ID number listed for 'administrative purposes'. This does not use the already logged on session (on the target machine) but I'm assuming starts it's own, negating the resolution issues of an already logged in session...
Highlighted
Posted by
Henagon
Re: Teamviewer initializing display parameters and hangs Version 12.0.72365
I restarted TV on my host machine and it worked for several days.   This morning it's showing the same issue.
Highlighted
Posted by
Henagon
Same issue on 12.0.72365.
First logon succeeded, but screen got stuck after a couple of seconds. I tried reconnecting, but now it get's stuck like all the other people here.
Will have to wait till tomorrow to see if a restart fixes this.
Highlighted
Posted by
Henagon
Same here, on 12.0.72365
Works fine most of the time but when explorer crashes, Teamviewer can't connect at all until I go on the remote desktop and restart explorer
Highlighted
Posted by
Henagon
I don't think I'd mark this thread solved or my post as a solution.. it was just something I noticed.
The problem appears to be that Teamviewer may be contributing or causing explorer to crash and if you don't get a chance to restart explorer manually on the remote desktop; then you're SoL until you get to it.
Highlighted
Posted by
Henagon
In my case, explorer wasn't crashed. I just restarted TV.  Same credentials etc. so it's not that either.  I have my system (Windows 10) set to not sleep or hibernate but I have the impression that something is still going on with that or wake on lan or something similar..
Highlighted
Posted by
Henagon
Really wish there were some restart option that did not require my to log in to TeamViewer.system is frozen but it shows on the list of computers. clearly not completely frozen but when I try to connect I get the initializing display but nothing from there.
Highlighted
Posted by
Henagon
Re: Teamviewer initializing display parameters and hangs Version 12.0.71503/12.0.72365
Teamviewer only connects when a monitor is attached and display is on, so to say screensaver or power save are the cause. As soon one uses the system, it wakes up, and so the display, and teamviewer does work again.
Highlighted
Posted by
Henagon
I don't think that that is it, because RDP doesn't have those restrictions, and everytime Teamviewer won't connect anymore, I try to connect to the machine next to it, and cannot even RDP in. (I can, however, VPN in, successfully, but this time I forgot to have Spashtop running as my backup for this situation.) The other day, when this occurred, I tried to restart the RDP services from services.msc and they failed to stop. Had to kill the .exe manually.
Highlighted
Posted by
Henagon
Not sure what you mean.
I leave my PC on but turn the monitor off.  I can usually connnect with TeamViewer except when it intermittently gets this problem initializing display parameters.  But it can work for a week with no issue so I don't think it depends on the monitor being on.  Maybe I misunderstood you?
Highlighted
Posted by
Henagon
it seems the monitor being connected event if off is enough.
most important is power safe is off for the graphics.
some other software have the same issue, and some solutions even use dummy's plugs into graphics, check Google for how-to-create-dummy-plugs-for-your-graphics-cards.
Highlighted
Posted by
Trigon
I've had this issue a couple of times. Today, the solution was different.
I have a power controller at the remote computer. I can power-cycle it if needed. I did that today and it did not solve the issue. When I tried to connect after the power cycle, I got a "You've trieds to connect too many times..." . SInce the  computer was just power-cycled, I know it was not the other computer.
I found that if I kill TeamViewer_Service.exe AND tv_w32.exe and tv_x64.exe, then I was able to connect to the remote system.
Highlighted
Posted by
Trigon
It's happened twice today. Both times I was in a session when the mouse and keyboard ignored inputs - that is when problem started.
The second time, I tried only killing the local services.  It didn't help, I needed to reboot the remote system too.
Now I enabled remote desktop so that I may try more actions in the future.
Highlighted
Posted by
Henagon
Thanks .... the recommendation to " kill TeamViewer_Service.exe AND tv_w32.exe and tv_x64.exe"  is helpful information.
The following is just additional information on my experience and does not contain a remedy or fix:
I use TV to connect to many of my customers that are running separate and distinct computers .... TV has been perfect except for one of my customers.  For that customer I experience the "Initializing display parameters" issue every time I try to connect.  I know I have a solid connection because I can open the File Transfer tool and I can see the remote drives and files perfectly.  I can transfer files as well.  As a test, I wanted to eliminate any installation issues that might be at my customer end.  I also wanted to insure that both ends of the TV software were up to date.  As such, I had my customer download and use the TeamViewer "Quick Support" tool ( The download link is: https://download.teamviewer.com/download/TeamViewerQS_en.exe ) When I tried to make the "Quick Support"  connection,  it produced the same hang and message "Initializing display parameters" ... TeamViewer File Transfer was fully functional.  I run multiple monitors on my local system and my customer has single monitor.  While not a likely problem, I wanted to eliminate this as a potential conflict so I tried connecting from one of my computers that has single monitor .  Same hang and message were received.
Highlighted
Posted by
Digon
Having the same problem too - with different PCs it seems vary how often it will happen but now it's perhaps 80% of the time incredibly annoying.  Why is this marked solved it's patently not!
Highlighted
Posted by
Digon
I've raised a support ticket for this seeing as I have corp. licence.
Highlighted
Posted by
Henagon
Hi
I started to have this problem on a headless Mac Mini (TV set on HDMI) running El Capitan and version 11 of TV (since i upgraded to 12). For 4 years i connected like this to my Mac and since the latest update of macosx (i think) something is not right.
After many failures i observed that if i let a finder window opened it works. If i close all finder windows i cannot connect.
I used to connect from work (windows 7), from various iOS devices and my macbook pro. Until 2 weeks ago no problem.
FYI, my computer at work is also headless (display off) and i can connect very well from home.
So i think it's a mac os x problem for me
THX for feedback
Highlighted
Posted by
Henagon
 remote win10 pro headless computer have this problem .
Solved by these steps:
  1. connect with TV VPN (you must enabled it before)
  2. connect RDP to remote ip address, login
  3. RDP and VPN will disconnect when login success
  4. TV remote desktop works now
Highlighted
Posted by
Henagon
When TV remote doesn't work, TV VPN does not work, either. Have tried this many times.
Highlighted
Posted by
Henagon
SAME! Any solution on your end?
Highlighted
Posted by
Henagon
Unfortunately no.
I did recently change out my hardware, on my machine, from Intel to AMD, which required a Windows reinstall.  So far it hasn't been happening again, but what does happen is that when connected, via Teamviewer, Explorer.exe crashes and hangs up a LOT.  I think there's some kind of hook, or conflict, between the newest versions of Teamviewer and Windows Explorer, right now.  None of these crashes, lockups, ever happened in past versions, and I've been using since version 7 or 8.  Since the "unable-to-connect" issue seems to revolve around explorer.exe being locked up, on the remote side, I have a feeling that these issues are connected and I'll soon start seeing the inability to connect, like before.
Highlighted
Posted by
Henagon
I also had this problem with version 12 after updating from version 11 on two computers. After complet deinstallation und new installation of TV V12 on both Windows 10 computers this issue is solved.
TV Version 12 now works fine again.
Best
Olaf
Highlighted
Posted by
Trigon
For me the problem is so sporadic, that I can't really comment on solutions. I haven't seen the error since my last report.
Highlighted
Posted by
Henagon
 I"ve been using it for over a week without the issue.  But yesterday I had the problem and when I got home I opened TV and it looked ok.  I tested it and it worked.  I noticed that my PC had a new software update and remembered that I had restarted it that morning before I left for work.  So I rebooted the pc again and TV didn't work after boot.  I opened TV and it started to work.
Like you say, this seems to be pretty sporadic so I'm not sure if it's the actual problem but it looks like even though the service is restarted on a PC reboot that it doesn't wakeup unless I actually open it.
Highlighted
Posted by
Trigon
Same problem with latest version 12.0.75813. This is very serious since I was in the middle of working on a client computer and all the other employees in that office have gone home. Completely unable to finish the work!
Highlighted
Posted by
Photon
Here is what I had to do to resolve the issue. I have to turn off the power saving functions on the monitor and I have to leave the screen on and the computer logged on.
If I do not do this I can't connect to the computer from a remote location.
Highlighted
Posted by
Trigon
That doesn't work for me. I had it happen with a computer where I've never adjusted power saving one way or the other. Normally I have no problem with that computer. It was a one-off issue. When the client came into the office the next day I asked them to tell me what they saw on the screen and it said "my name" unable to ... something or other. I had them close the popup and was able to connect. It hasn't re-occurred since!
Highlighted
Posted by
Photon
I have this problem for more than a year, it only works when the TV or attached display has power on.
I solved it by using another program: **Third Party Product**, works like charm.
Highlighted
Posted by
Digon
I'm still having the issue after the Creators update for windows 10 - the symptoms are always the same:
Connect to remote system, hang 'initialising display..'
On remote system 'explorer.exe' is hung (crashed).   Resolving it is possible by killing the task and restarting explorer.
I've had this happen on 3 different systems now and the symptoms are always exactly the same - no explorer.exe crashes occur on any system except when using teamviewer (the system reliability monitor is an easy way to visualise this).   As a possible workaround you can setup a task to monitor 'explorer.exe' and kill/restart it when it hangs.  This gives you a fighting chance of reconnecting.
I'm using Restart On Crash - http://w-shadow.com/blog/2009/03/04/restart-on-crash/
I'd be interested to see if this helps any of you!
Highlighted
Posted by
Henagon
I have the exact same issue with Windows 10 after last updates (KB4015217). In one of my pcs, I have also received the creators update. I' ve never had this kind of problems before. The TV version is 12.0.75.813.
Highlighted
Posted by
Henagon
I'm having the same problem here, very annoying, already happened twice!
  • TV running on Windows 10 or Ubuntu 16.04 (tried both)
  • Target running Ubuntu 16.04
This issue appears when I'm switching display resolution in a remote session - the transmitted screen freezes and the connection drops. When I reconnect, the process hangs in the initialize display parameters part.
Update: Suddenly I could connect to the ubuntu machine again, after around 15 minutes - but the screen is just freezed, I cannot do anything. Really strange.
The only working way to fix this, is to restart the target machine, which is very frustrating ;-)
Please fix that!
Highlighted
Posted by
Henagon
I've installed this Restart-on-crash application, and after a week or so my experience is that it might work. I haven't had this error since I installed it.
I suppose it's not proof, because I may have had week long periods without crashes before, but at least I can't rule out that it works :)
Highlighted
Posted by
Henagon
Same here bekou, same version, 12.0.75.813. Connected reliably from home for years, now my work machine freezes, won't allow input, close the connection and it hangs at initializing display parameters, and after a while it just goes to authentication rejected.  Super annoying.
I've only noticed this since the Creators Update.
Highlighted
Posted by
Henagon
Solved?  Same problem here too.  Anybody at TeamViewer look at these threads?  Seems to be a long common bug.  I also think it's a resolution problem since TeamViewer seems to be terrible at switching resolutions properly.  I think it may be connecting.  It just can't make it pass the "Initializing display parameters" step in the process.
Highlighted
Posted by
Trigon
Don't if others are having this problem but whenever there's an update to this subject I get the same email notification repeated multiple times! E.g., so far today I have received this same notification six times! TEAMVIEWER: ARE YOU PAYING ATTENTION???
Highlighted
Posted by
Henagon
Hi, I reverted to TV 11 for now and it solved my problem. This is not a solution but it works for now since I don't have time experimenting at the moment with different TV 12 versions. I send an email to people from TV and they told me to run an app (TV support collector) that they have to collect the logs from the host and target machines and send them the zip files. I'll do it when I have more time available but TV 11 seems to solve the issue for 2 w10 creators update pcs.
---edited ---
Same issue in version 11 - authentication rejected like @thado said but without crashing. When I closed the message session timeout, I was able to reconnect!
Just in case that somebody is listening the error that I get in TV 11 log file is:
CLoginServer::CheckIfConnectionIsAllowed: Incoming connection from xxx denied, because TeamViewer is not visible
CLoginServer::runServer: Connection is not allowed
Highlighted
Posted by
Photon
I suspect you installed TV over an RDP session originally.  Remove TV, gain direct console access to the server (not RDP access) then reinstall TV.  In my case I was able to uninstall TV then reinstall TV over supermicro IPMI Java based console and that got it working for me.  FYI Logme (now GoToMyPC I think they call it) had this same issue years ago before I switched to TV.
Highlighted
Posted by
Digon
I have the same problem, although I am using version 12.0.77242.
I am using TV on this PC both for login to another PC and for login to this PC from the other one.
Both cases do not work anymore.
From this PC I get initialization display then hanging window. From the other PC, after initialization, the connexion ends without any message.
Everything used to work fine until some recent time. Hoever, I am unable to tell when the problem appeared. It may be after installing latest Windows 10 upgrade.
Any solution available ?
Highlighted
Posted by
Henagon
@Mulsambe: For me in TV 12.0.77242, the issue remains.
Try TV 11. This older version solved the problem.
Highlighted
Posted by
Digon
Thank you for the suggestion.
However, TV11 will not work for login on the remote PC running TV12.
I will have to downgrade to TV11 on both PCs, and also on all other family PCs already running TV12...
Highlighted
Posted by
Henagon
Ok, a couple things have changed and I am able to connect without issue.  In fact, I am typing this on my remote machine now.
1. Updated both remote and local to 12.0.77242
2. My home version was saying the typical "license has expired".  I re-entered my corp license.
3. On a suggestion posted here, I changed my power plan settings to never / never for turning off the display and put the computer to sleep.
I have tested multiple times since these changes and haven't had an issue.
Highlighted
Posted by
Digon
Unfortunately, this does not work for me.
- checked version 12.0.77242 on both computers
- no license needed : says Free license (personal usage)
- disabled display sleeping on remote laptop
I have 4 machines running TV12.
Only this one is unable to remotely log on any other.
And only this one rejects remote login.
Could be linked to latest Windows version installed recently.
Current version : Windows 10 Professional 10.0.15063
Do someone use TV with this Windows version ?
Highlighted
Posted by
Henagon
I already have it not installed on both ends and I still have the issue.  Based on the message saying that I can connect to any "active session" I'm wondering if this is on purpose for some legal reason?  I don't see why seeing as it still takes up a TS session anyway.  Please update if this is solved.
Highlighted
Posted by
Henagon
I am having this trouble with many of my users and computers. We are all on Version 12. Downgrading the entire company to Version 11 is not a solution. Please correct the issue.
Highlighted
Posted by
Henagon
Getting on the remote computer and restarting processes is not a solution. The entire point of remote administration is that I can't easily reach the remote computer to do that. Whatever is causing the crash/lockup needs to be found and fixed.
I grabbed the logs from my computer and the remote computer when it happened. But this new board doesn't let me attach files.
Highlighted
Posted by
Henagon
I have the same problem on teamviewer 12 "teamviewer initializing display parameters stuck".
If I can connect to remote computer the "right mouse click" on desktop to set "Display options" also does not work. I get an error message.
But usually I get stuck in "initializing display parameters"
Highlighted
Posted by
Digon
Had a reliable solution to this problem been found? This just started happening recently to me. My friend is 98 years old and I help him via screensharing frequently. But the last month I've been stuck on this "initializing display paramenters."
We are both on the latest Mac version.
I tried rebooting both machines. And I did a minor upgrade of my version 12 today but it didn't help.
Thanks.
Highlighted
Posted by
Henagon
I had the same issue. Both machines Version 12 and Windows 10 Pro, stuck in Initializing display parameters.
I was able to work around it: In TV client go to Settings -> Remote control -> disabled "Remove External Background" and selected "Optimal Quality" under quality. Then I connected and it worked again. Rebooted the machine to be sure.
Note: I use a Dutch version so the translation may be different in your TV.
