Teamviewer 13 and Raspberry4 headless problem
I've a new Raspberry 4 with Raspbian OS:
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
I installed the package  teamviewer-host_13.1.1548_armhf.deb from pi user.
I accepted the license and set the password.
If I run 'teamviewer info I have:
pi@raspberrypi:~ $ teamviewer info
TeamViewer 13.1.1548 (DEB)
TeamViewer ID: 2534*****
teamviewerd status ● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-08-07 14:42:30 CEST; 9min ago
Process: 2102 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited, status=0/SUCCESS)
Main PID: 2104 (teamviewerd)
Tasks: 17 (limit: 3862)
CGroup: /system.slice/teamviewerd.service
└─2104 /opt/teamviewer/tv_bin/teamviewerd -d
ago 07 14:42:30 raspberrypi systemd[1]: Starting TeamViewer remote control daemon...
ago 07 14:42:30 raspberrypi systemd[1]: teamviewerd.service: Can't open PID file /run/teamviewerd.pid (yet?) after start: No such file or directory
ago 07 14:42:30 raspberrypi systemd[1]: Started TeamViewer remote control daemon.
Strange, the file /run/teamviewerd.pid is there and readable (???).
If I run 'ps aux | grep team' I have:
pi@raspberrypi:~ $ ps uax | grep team
root 2104 0.1 0.4 164840 8384 ? Sl 14:42 0:00 /opt/teamviewer/tv_bin/teamviewerd -d
pi 2167 0.0 0.0 7368 564 pts/0 S+ 14:53 0:00 grep --color=auto team
Usually there are three processes, so sometihng is missing.
If I try to connect from other PC I receive an error - the device is not connected
Please, how can I solve it?
