Highlighted
Posted by
Photon
Debian 8.8 headless machine problem
hi, i have succefully installed teamviewer but when i try to launch setup i have this error:
La console framebuffer semble ne pas être disponible ou son format est incorrect.Assurez-vous de l'accessibilité de /dev/fb0 et de sa configuration à une profondeur de 32 bits.
1 Reply
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Solution
Re: Debian 8.8 headless machine problem
Dear freelux,
Please edit your /etc/default/grub file and add these two lines.
GRUB_GFXMODE=1024x768x32
GRUB_GFXPAYLOAD_LINUX=keep
Save the file and run the command
sudo grub2-mkconfig -o /boot/grub2/grub.cfg
Then reboot the computer.
Hope this solution works for you.
Christian
View solution in original post
1 Reply
Highlighted
TeamViewer Staff
Solution
Dear freelux,
Christian
