TeamViewer 14 doesn't open after trying to open it after 2 months since I opened it last time
Announcements
First Step Guides
  1. Are you new to TeamViewer and Home Office and need some help? Check out our FAQ here.
  2. New to the Remote Access Plan? Find our first steps FAQ here.
  3. Are you new to blizz and online meetings or classes and need some help? Check out our FAQ here.
Highlighted
Posted by
Photon
TeamViewer 14 doesn't open after trying to open it after 2 months since I opened it last time. I tried to re-install it but nothing has changed. Then it came to my mind that I could reboot, I rebooted my pc but nothing has changed. I re-installed it 3-4 times but nothing changed. When I try to open it it shows an error message that the programme can't be found on my pc. Can someone help me? Ty
1 Reply
1 Reply
Highlighted
Posted by Moderator Moderator
Moderator
Re: TeamViewer 14 doesn't open after trying to open it after 2 months since I opened it last time
Hi @emrefez4
Can you kindly try to tick the option of Remove Settings when you are uninstall TeamViewer please. Then visit TeamViewer download page to download TeamViewer please. Meantime, kindly check out Which operating systems are supported? for software and operating system version compatibility please.
Hope the steps above are helpful.
