higher resolutions (up to 1920x900) MISSING while connected with eeePC 701 (800x480)
Hello at all,
I used a eeePC 701 with Windows 2000 and TeamViewer 5. WITHOUT any problems.
eeePC 701 is able to show 800x480 (physical) and 800x600 (virtuell with PAN-function)
TeamViewer 5 at eeePC and TeamViewer 10 at my main computer WAS able to show a resolution up to 1920x900 pixel.
NOW I updated eeePC also to Win7/32 and TeamViewer 10
=> I used the original driver of Win7 first
=> Then I installed the WinXP driver (without error messages)
BUT: The possibility of displaying higher resolutions (up to 1920x900) in TeamViewer is missing!
Question:
i) is this a problem of TeamViewer?
ii) is this a problem of the newer versions of TeamViewer? (I try to install version 5 while waiting for answers )
thanks a lot
additional Info...
I deinstalled version 10 and started version 7 & version 5 (with & without installation)
i) ver 5 has had problems after installation (Installation Part was OK ... Program "is no Win32-Application" - not very urgent. Its an old program.)
ii) ver 7 (start OK) ... but no advantage with monitor resolution.0
