Problems with TV installation on Ubuntu 18.04
arturorguez35
arturorguez35 Posts: 1 Newbie
edited December 2020 in Linux only
I'm trying to install teamviewer_15.13.6_amd64.deb but I get the following messages.
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'teamviewer' instead of './teamviewer_15.13.6_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 teamviewer : Depends: libqt5webkit5 (>= 5.5) but it is not installable or
            qt56-teamviewer but it is not installable
E: Unable to correct problems, you have held broken packages.
Can anyone help me to solve this?
Thanks in advance!
