My teamviewer feeses all the time
It stay connected in aprox 2minutes then I’ve to reload.
Very irritating
I have a business abn. Running Windows 10
The same issue is happening to me. Only one computer at the site is affected; all other PCs function normally. Since a new computer was installed, there has been a problem. TeamViewer has been uninstalled and reinstalled, and a host custom link has been performed. Still not functioning correctly. Upon bootup, TeamViewer launches before shutting down. I need someone else to launch TeamViewer and log in using a different remote software. I'm forced off the computer after a short while of working, and TeamViewer is no longer active.
I am having this same problem. Happens with only 1 computer at the location, all other computers run fine. Problem has been since new computer was installed. Have rebooted computer, uninstalled and re-installed TeamViewer, Re did host custom link. Still not working properly. TeamViewer starts on boot up, then turns off. I have to have someone else sign in using a different remote program and start TeamViewer. After I am working for a few minutes I am kicked off the computer and TeamViewer is no longer running.
Hello @Sverre,
Could you please describe a little more the connection interruptions?
Do you have an error message? Could you send relevant screenshots?
It is still the same problem.....getting thrown out after a couples of minutes. And it is not the internet connection.
Can it be my verison? Can I evt reinstall?
This is very irritating for me. I connect to my customers POS daily.
PLEASE help me?
No, it is not related to internet connection.
Both sides is online when it happens.
Did you try if this is related to Your's or Remote internet connection?
