I've applied the WOL configuration to two Dell Optiplex 7010 desktops. From the 'via another computer' I can wake one both from Shutdown and Sleep modes but the other will only wake up from Sleep mode and not from Shutdown. The PC has deep sleep disabled and latest BIOS installed.
The PC is connected directly by ethernet cable to my home router into which the 'via another computer' is also connected. The PC that does WOL from shutdown is connected via the 3-pin electric plugs of the house using Devolo plugs. I will continue to experiment as to what the cause is and update this post again.
Meanwhile, if anyone has had the experience, perhaps they would reply here, thanks.
Kind regards, Conor
