How can I talk to someone about getting new add-on for android devices
I has 3 devices and none work all 3 are android there is no touchscreen add-on for them that work the devices are
Vankyo matrix pad s30
( also the matrix pad S20 doesn't work I have tried that as well as I mother has 1 so If you can do an add on for that as well would be great as I help her a lot with it)
Ulefone Note 9P
And a Motorola Moto G9 Play
Yes I have tried the Universal add-on and it will not give you touchscreen ability you still have to use it like a mouse I no it can be done as you add-on for the lenovo worked great unfortunately my one is not the greatest and so got new tablets be they don't have any descent add-ons for them
Really hope you can help
