The box on the "Show Comment Window After Each Session" is greyed out with the check mark in place. How do I remove the check mark when the box is greyed out?
Maybe an uninstallation with deleting the settings and reinstallation will help:
Hello JeanK
The "Log sessions for connection reporting" is also greyed out & I can't check or un-check that one either. Any other suggestions?
Hello @RogueOne,
You need to first tick the Log sessions for connection reporting feature:
Then, you will be able to untick both features:
See what's new at TeamViewer
