Connection 2FA for certain connections
mgstrick
Posts: 1 Newbie
Hello!
Is there a way to let certain users bypass the new 2FA connection option? For example, I have 6 total users who need to access a device, but only four of them need approved through a push notification. The other two can access the device at any time without having to have a 2FA approval.
Thank you!
Hello @mgstrick,
This is currently not possible.
If 2FA for connections is enabled on a device, it will affect any connection to this device.
