Uptime Monitor - "Unbekannter Fehler" / "Unknown Error"
Hi
I'm using a simple uptime-monitor that is monitoring an api health endpoint each minute.
Response will always be something like
{"version":"V5.4.5_1394","dbCheck":1}
Monitor was set up to check for string "dbCheck":1
First the monitor is running as expected. But after a couple of time I get Alarms / Errors "Unknown Error", even if the api / page is available. There is no way to figure out, what exactly is the problem.
When making a change on the existing monitor (e.g. changing the search string forth and back), the monitor is running again.
How to avoid the "unknown errors" or at least have some info, what exactly is the issue here?
Thanks in advance
